How do YOU drain coolant when you refresh fluid?
Does anyone have air in their top hose or should it be full of fluid?
I honestly don't know.
The lady said it got up to 220 today. 95 degrees for a high in the city.
I gave the top hose a squeeze and there's clearly air in there.
Should I bleed all that out somehow or is it normal to have air in there?
edit... There was a little in there. I'm just being paranoid.
After reading and following this thread my 98 "MJ" had a great 30 mile test run with a/c on in 90 deg weather and 86% humidity. I think I can now drive it and not worry about the temps anymore. Highway speed 196 Deg Idle in traffic for almost 5 min, road blocked scraping up a head on, 206 deg back to the shop and was not even hot enough to trip the cooling fans, yes they do work.
Thanks for the information.
I would do a pressure test to MAKE sure that a sleeve has not slipped. As far as a top hose you will have AIR when the thermostat closes and stops water flow.
If I'm just doing a drain and fill I remove lower hose, go inside and eat lunch.
Replace lower hose, refill, bleed and go.
If I'm replacing the t-stat with drain and fill I also back flush the radiator and block with the garden hose.
If I'm just replacing the t-stat I just remove the t-stat, let drain out what drains out and put it back together, refill and bleed.
Hey spike when just replacing t-stat going by your method about how much coolant can I expect to lose? I have a whole new bottle just didnt know if this was enough or if I should go ahead and pick up another bottle
The system holds 3 gallons, you should be good. I mix about 60% distilled h20 to 40% coolant. Unless the bottle you have is pre mix. Even then, I can't imagine losing more than a gallon when changing a t stat.
I've since installed drains in my radiators, but before that, or on one that doesn't have a drain I made a drain method with some vinyl tubing, a 'T' connector, and a cork.
What I ended up with was a long piece of tubing to insert in the radiator, it runs down to the 'T', then continues with a short piece in to the jug. On the branch of the 'T' I have another longish piece I use to manually start the siphon the old school way, just blocking off the end in the jug while I do it. Once it's starts flowing I stick the cork in the "mouth piece".
Works the same for siphoning fuel in to the tank from jerry cans on the roof rack. Cost me about $2.
luxury1
12-03-2008 07:09 AM
06, 1996, 351, 98, antifreeze, cleveland, coolant, drain, draincoolant, land, plug, range, rover, thermostat, type
