gear oil,,,refresh my memory
Old Oct 10, 2009 | 01:32 AM
sloppyjoe's Avatar
Default gear oil,,,refresh my memory
rave is on my other laptop with bad keypad,,,
how much oil for the diffs and trans case?
doing the diffs this weekend with a oil change. and i cant remember how much i need for the diffs and T-CASE.
gonna be a chore with one arm in a sling.
Old Oct 10, 2009 | 06:36 AM
lipadj46's Avatar
front 1.8
rear 1.8
transfer 2.2
Good luck the center is hard enough to do with 2 hands.
Old Oct 10, 2009 | 09:45 AM
Are you going with the standard gear oil in the 90W range or the HD stuff in the 75W/140 range?
Remember your truck came with and should have synthetic oil as a replacement.
Old Oct 10, 2009 | 11:21 AM
sloppyjoe's Avatar
thanks mike,
i never use standard oil in anything. always always synthetic in everything =)
i have to see what i have in my shop. i believe i have 5 to 7 qts of valvoline synthetic gear oil in my shop. not sure on the viscosity thought. i know its most likely a 75/90 cause i had a bunch of it from when i did the gearbox on the 308. i always buy lots when i find a good sale on oils and lubes.
i was planning on doing the T-case but i might wait till later when i can have a extra set of hands to help out.
Old Oct 10, 2009 | 06:37 PM
You will want 7 qts on hand Sloppy.
Old Oct 10, 2009 | 10:24 PM
sloppyjoe's Avatar
i had 5 qts in the garage.
so i did the diffs. it was valvoline synthetic 75/90. went pretty easy. small hand pump i bought at the parts store is always a lifesaver and even more so with one arm in a sling.
sale on mobil 1 synthetics. 5 qts of any weight plus mobil filter for 29.99. heck of a deal. +1 qt at the sale price. so i got my mobil 1 10/40 high mileage and 2 gallons of peak 50/50 mix for $10. and as always a bottle of water wetter.
all went well and i even managed to not break the plastic fill plugs on the diffs.
coolant tomorrow.
next is T-case and tranny. then belt and power steering fluid and the 60k will be done.
Old Oct 11, 2009 | 09:30 AM
oysterhead's Avatar
why is the transfer case any more difficult than the diffs?
because it's tough to access the fill and drain plugs?
Old Oct 11, 2009 | 09:38 AM
lipadj46's Avatar
Yes the fill plug can be hard to get off especially if this is the 1st time it's been cracked open. It is slightly behind the E-brake drum and a wobble extension makes it easier to get to.
Old Oct 11, 2009 | 12:08 PM
sloppyjoe's Avatar
yeah i took a look at it and said "another day"
plus the tranny pan has to come off when i service it. so that was another 2 arm job
wallyman424
Nov 7, 2014 03:12 PM
Narrowrd
Jun 6, 2013 04:25 PM
bigcraigman
Jul 1, 2012 01:32 PM
ToddD
Jun 26, 2012 06:58 AM
luxury1
Dec 3, 2008 07:09 AM
