How to get shifter out of center console?
I've been diagnosing the problem with my shifter today (stuck in park) It looks to me like the safety for the brake pedal in order to shift out of park is in-operable. If you push the pin in manually you can shift just fine until you put it back into park. The problem I am having right now is, how the heck do you get the actual shifter out of the console? Everything has been taken appart, but the shifter assembly is wider than the hole on both the top and bottom, so it won't come out. Is there a way to disassemble the shifter assembly to get it out?
Thank you for your time!
-Ethan
-Ethan
If you have it disassembled down far enough,i.e.- center console removed, black plastic trim with the park,reverse,neutral,etc. on it removed, you should see a flat piece of sheetmetal with the shifter opening in the center. Around the perimeter of the sheetmetal are rivets. The rivets have to be drilled out and the sheetmetal removed.
But before you do that, did you check the usual things like fuses, brake light switch, are the brake lights coming on when you press the brakes?
Haha yeaaa It's looking like I'm gonna have to dig into the electrical gremlins now.. I was hoping to put that off for a bit..
It wasn't terribly hard to get that center console out, sounds like I probably did it for no reason, but atleast its all clean now! The people that had this truck before me were friggin slobbsss
Looks like now is the time to lube the crap out of the CDL and get that so it shifts again.
As per my understanding, if your CDL doesnt shift it may not be as easy as just lubing the top up like Danny's pic. Danny actually has some pretty good info in a differentthread regarding the CDL, find it here:
https://landroverforums.com/forum/sh...tenance&page=2
near the bottom of the page. May want to leave that console out while you think about that CDL
good luck
good luck
on
The two pics I posted may be misleading, they are just views after tearing the CDL shifter completely down, replacing a few small highly corroded parts, cleaning it really good, reassembling, then filling all the open spaces with the thick red Lucas Gear Lube during reassembly.
Mine was severely nasty and corroded. I took it completely out and disassembled it all the way. It now works "Smooth as Butter" both for CDL and High/Low. Mine would shift high to low and back but would not engage CDL, I also had to replace the CDL shifter Switch.
You can put a wrench on the lower pivot point and rotate it that way. I had to do that to get it to move initially. Spray it real good for several days in advance with PB Blaster to help free it up.
elboy0712
04-02-2010 11:52 AM
