How long to build oil pressure after rebuild?
I rebuilt the motor with all new internals (minus pistons and oil pump) last year and the truck ran mostly fine. It was lacking power and had excessive blow by so I pulled it and had the machine shop check the pistons and rings (gave him the Rave specs). We ended up buying new pistons and rings. Put it all back together and ended up replacing the oil pump gears while I was at it. I just fired it up for the first time and the oil pressure light never turned off after 10 seconds so I killed it.
How long should it take to pressurize the whole system after being completely drained? Did I kill it too soon or do I need to investigate further?
BTW I did that after trying the whole back flow oil into pump via hose thru the oil filter mount thing. That didn't work at all for me.
One more thing i did was fill my filter with oil before installing it, one less thing for pump to fill with oil on start up.
