How to Lube/Grease D1 Front and Rear Drive Shafts?
Can someone point me to a thread, external site, or just tell me here how to lube the front and rear drive shafts on a 1997 D1?
Like, where are all the grease fittings, which type of grease gun and grease should be used, etc.
I assume they are serviceable with the exception of the rotoflex in the rear.
Yes?
This seems like a good candidate for the D1 tech section, but I don't see it there.
Cheers and Thanks!
- Chris (aka LeakyDisco)
Yes?
Cheers and Thanks!
There's a thread here about rebuilding propshafts that includes lubing them. Unfortunately it's only linked under the DII section for some reason.
https://landroverforums.com/forum/sh...ad.php?t=29302
Now, I spend most of my day on the computer writing software, but I have begun a quest to do most of the work on my truck, which I am becoming more familiar with every day, thanks to poking around the vehicle, and to the helpful folks on this site (including you).
The term "blast" was merely a figure of speech meant to express my excitement over something as trivial as greasing u-joints--something I have never done before.
Cheers,
- Chris
One good way to learn it is to lay underneath it on a creeper and see if you can identify the basic pieces of the various systems. Get you a creeper from Harbor Freight if you don't have a good one already. They have a nice molded low profile heavy duty six wheel unit for 30 bucks on sale.
Figure out what is what. Take some pics of it. See what is leaking and from where.
Clean the various items that look like they need it, spray the drain plugs with PB Blaster. Go get you all the various fluids for an oil change, diff fluid change, tranny and transfer case. You should get fresh fluids in them right away so you got a good baseline.
Get your hands dirty and look it over good to see what may need attention.
Download the RAVE, print the sections you need and get started.
I've identified two oil leaks (upper cooler hose and oil pan leaking from bolts). My shortlist includes changing out both cooler lines and replacing the pan gasket (and maybe the bolts/nuts if I can find new ones). Both of those jobs seem straightforward.
I had a shop do all the transfer case, tranny, and differential oils within the last 2 years, but I plan on doing it again myself, and adding that to my regular maintenance schedule. She gets oil changes every 3000 miles, though that comes infrequently given my driving habits, so I plan on increasing changes to once every 3 months.
Those are just the immediate things I need to take care of.
