I shall call it "Progress"
Old Nov 19, 2010 | 10:01 AM
Garrett's Avatar
Default I shall call it "Progress"
The rear of my Disco has always been noisy. Finally got around to picking up a pair of rotors, calipers and pads and new Bilstein shocks
Everything went smoothly. Replacing the rotors was interesting though, are the fronts the same way?
I did all bearings and seals. The grease seal on the driver's side had failed and what was in there was just a mushy mess of grease and water. Bearings were rusty. Looks like someone had done that side before, they did not put the lock washer on and the hub nut was held on by only one thread!
Shocks were so easy, took 15 minutes each side and it rides sooo much better! I could press the old shocks with one hand and they had no rebound. While doing the shocks, I noticed the rear sway bar links had come undone. The part of the link that is mounted on the truck had quite literally popped out of the socket on the link! Very odd. Next on the list.
Few pics:
0_IMAG0207.jpg?t=1290182215
Old rotor.
Old pad, things mint, right?
0_IMAG0206.jpg?t=1290182215
Old.............................New.
Had some old burnt orange paint from when I painted the BBS wheels on my BMW, thought it was fitting
0_IMAG0209.jpg?t=1290182215
All done!
Old Nov 19, 2010 | 10:30 AM
hilltoppersx's Avatar
massive blurry pictures!! glad it all worked out for you
Old Nov 19, 2010 | 10:37 AM
antichrist's Avatar
Front and rear hubs are identical so the process for changing the rotors is the same.
When you do the fronts, use hub seal RTC3511 if you do much off-roading, it's a better seal.
Old Nov 19, 2010 | 10:39 AM
llesra's Avatar
haha i ran into the same issue with my rear brakes making a strange noise awhile back. fronts are the same, minus the abs ring inside the rotor. which pads and rotors did you use?
Old Nov 19, 2010 | 10:43 AM
Garrett's Avatar
Pads and rotors are both Wagner. I was going to do Brembo rotors cause they're only 45$ a piece but I was in a rush.
Old Nov 19, 2010 | 01:37 PM
Garrett's Avatar
And then I get home to this in the mail!
weeeemirror.jpg?t=1290195446
Old Nov 19, 2010 | 02:04 PM
? an isuzu rodeo was in your mail?
Old Nov 19, 2010 | 03:15 PM
Garrett's Avatar
Yes.
tenchar
Old Nov 19, 2010 | 06:01 PM
Danny Lee 97 Disco's Avatar
Wow, wish somebody would mail me one for errands and such. My oldest brother is on his second one and loves them.
It looks like they put my old calipers on yout truck after I threw them away. I got the same pic of my old black one beside my new shiny caliper, it came with a goldish hue coating of some sort that I cannot remember at the moment.
Old Nov 19, 2010 | 06:07 PM
Garrett's Avatar
No the non melted auto dimming rear view with map lights.
