I spoke too soon… Cruise Control
Old Mar 26, 2014 | 07:43 PM
Snowdog's Avatar
Default I spoke too soon… Cruise Control
Well, after installing a new (used) vacuum pump and all new vacuum lines, I had functioning CC. For one afternoon. Went to use it this morning and nothing. So I pulled the plug and jumped the appropriate terminals, and the pump is sucking and the diaphragm is moving. I guess maybe the old CC module might have died? Anyone have any idea of what the issue could be if not the module? And if it is the module, am I to understand that a DII unit is the better way to go?
Thanks!
Old Mar 27, 2014 | 11:12 AM
OverRover's Avatar
Just a thought, how about the cc switch(ERR2622) at the brake pedal???
Switch Cruise - Control - Brake (Genuine Part # ERR2622) - Land Rover switches/control unit/actuators from Atlantic British
I had one of these cause odd problems with the cc.
Old Apr 5, 2014 | 09:47 AM
Snowdog's Avatar
Smile
I replaced the cruise ECU with a DII unit, and previously all the vacuum lines and the pump, and it worked - sort of. It set a speed, but wouldn't hold it with any resistance like a headwind or hill. So, I thought the only part I haven't replaced that could be responsible is the bellows. It has some signs of cracking, so as an experiment I used some silicone to thinly coat the bellows, helping to seal any cracks seen or unseen. One 500 mile trip later, and the cruise is operating as it should! Now I know that a new bellows will resolve the last of the CC issues.
Thanks to these threads and their authors:
https://landroverforums.com/forum/di...15/#post433770
https://landroverforums.com/forum/di...40/#post380616
This is a great forum; 10k miles in four months of driving has only been possible because of the knowledge and advice of the members on here. Thanks everyone!
Old Jun 14, 2014 | 11:48 AM
rickroverover's Avatar
Default Cruise issues..
Question on cc troubleshooting. Anyone have or have seen instructions like a flow chart that will assist finding and fixing CC?
I have replaced a lot of hose but a help would be .. like - switch on, voltage should be ** at this location.. if so vacuum at this location should be ** with unit on.. if so etc etc..
I have studied the rave but it is not giving values or relating events when activated.
Thanks!
DUH!!! I just saw the links in the above message.. sorry ( leaving up ,, in case )
Evan5291
Nov 21, 2017 07:59 AM
05LR3V8SE
Jul 19, 2016 04:03 PM
yukonridin23
Sep 24, 2009 05:08 PM
southfloridadiscoII
Jun 28, 2009 11:03 PM
flavorking
Feb 10, 2008 12:33 PM
