I think my distributor is in wrong??? 94 Discovery
Old Mar 18, 2011 | 04:18 PM
ara25's Avatar
Thank you to all of those who gave advice. When I figure the other problems out I will post the results.
Old Mar 18, 2011 | 08:18 PM
losinov's Avatar
I find the easiest way to pull out rotor is too chisel it off with a flathead, you don't have to worry about the internals of the distributor underneath if you do it that way
Old Mar 18, 2011 | 08:54 PM
antichrist's Avatar
Originally Posted by ara25
After checking for TDC and then inspecting the distributor I noticed that some parts inside the body were loose and rolling around so I took apart to find that both springs and both retaing clips were off the posts. Still kind of confused as to how that could have happened.
Did you change out the rotor also? You only mentioned replacing the wires. As mentioned, that's not an uncommon occurrence when replacing the rotor, if not really careful.
Old Mar 18, 2011 | 10:08 PM
ara25's Avatar
yeah when I changed the plugs i did all the wires and cap and rotor and then thinking back unfortunately I did "yank" the rotor off(rover rookie mistake)
Old Mar 19, 2011 | 09:21 PM
ara25's Avatar
Default Confessions of an Idiot
Well turn signals, brake interlock switch, and brake lights(well they work like when I bought it) it was a blown fuse (#1), guess I didn't check all of them. The engine is idling smooth at about 700 RPM's timing is set at 5 degrees BTDC. Apparently I had the coolant sensor plug upside down and that tripped the computer to display code 14 and causing the vehicle to idle rough and erraticlly. How do I reset the computer and is the computer whats under my passenger seat or is that the amp? I'm begining think I should have my wrenches revoked for the benefit of my Rover... Oh well I did get a crash course in Land Rover's thanks to my stupidity... Thanks again
howardw
Aug 21, 2009 06:57 AM
lipadj46
Aug 19, 2009 06:11 PM
motormikeyman
Apr 22, 2008 06:54 PM
mestupstud
Nov 10, 2007 07:49 AM
Ex CCS Racer
Tires
Oct 21, 2007 08:36 PM
