IAC/ Throttle Adjustment
Old May 24, 2019 | 03:26 PM
Mo 3's Avatar
Default IAC/ Throttle Adjustment
How do I properly adjust the throttle control is there a specific method or just adjust until it stops shutting off while idling?
Old May 24, 2019 | 03:52 PM
hrhoward's Avatar
Hi there,
If you don't have a copy of the RAVE yet, get it. Find a post by WaltNYC, he has links in his signature.
Instructions for mechanically adjusting the throttle linkage are in there.
Idle air control valve or throttle body could be dirty. Linkage could be sticky.
Old May 25, 2019 | 05:14 PM
WaltNYC's Avatar
I'd clean the IACV before I'd mess with idle. You can get yourself to a point where you'll need to re-flash your ECU if everything is not set properly. The truth is the ECU should set idle.
LRD2&ME
May 13, 2019 09:25 PM
VikingDiesel
Apr 6, 2018 11:11 AM
min624
Sep 7, 2014 07:08 PM
psykokid
Nov 16, 2011 07:32 PM
jasons
Jul 30, 2009 08:15 AM
