Iacv problem returns, can I temporarily bypass it?
Old Jun 13, 2014 | 08:03 PM
s10lowrider1994's Avatar
Default Iacv problem returns, can I temporarily bypass it?
So I put a new iacv on and it worked for a day. Next morning when I started it up, idle went back up to like 1500. I have read through certain diy re learn things on here and they simply don't work, at least not permanently. I can trick it into idling perfect if I do the whole turn key on/off unplug/ plug back in scenario but it only works until I turn it off. Anyway is there some method to bypass this dumb thing until I can get it into the dealer for an adaptive value reset?
Old Jun 13, 2014 | 08:35 PM
ihscouts's Avatar
Your at the point of no return, it's a reset or nothing if you've already tried the work-a-round.
Old Jun 13, 2014 | 08:44 PM
Ha I figured as much, I guess I'll have to find my way to the shop soon. Will it hurt anything to drive it there?
Old Jun 13, 2014 | 08:50 PM
ihscouts's Avatar
Only your fuel mileage......
And be careful when coming to a full stop, I'm sure you know why. Just give yourself a little more room.
Old Jun 13, 2014 | 09:51 PM
XCELLER8's Avatar
fwiw...I went through this too(still am....havent had a chance to travel to a dealer or elsewhere) but this worked for me >>> go through the motions as you have done, and when the engine is warmed up & running....just unplug the pia iacv.....and leave it unplugged>>> you will likely need to just touch the gas pedal when you start the engine cold but as soon as it warms up a little it'll be fine....you can also adjust the throttle cable a little too if needed to speed it up some. I have driven mine about 5000 miles with it this way......it took 4500 miles before I got a code for "open circuit" on the iacv.
Old Jun 14, 2014 | 06:51 AM
TOM R's Avatar
Just find an Indy shop to reset seems to start at $20 and go up for the reset
You will not want to drive it getting 8- MPG or less
This happened to me 2 times 2 different ecm, my TPS was getting shorted causing the issue, fixed TPS problem and had ecm reset issue has not returned
Victoria
Apr 9, 2014 09:38 AM
cipher982
Feb 28, 2013 06:11 PM
elboy0712
Dec 19, 2010 02:48 PM
Chrisinhouston
May 2, 2008 10:38 PM
surfchiro
Defender
Nov 12, 2006 09:38 PM
