ideas on an age old problem - Hood liner issues
Old Jun 12, 2021 | 09:13 AM
rickroverover's Avatar
Default ideas on an age old problem - Hood liner issues
I like many have found it hard to throw away things that just might be usable.
Like that almost usable hood liner.
I can't help but wonder if...
A) can't we use some epoxy based substance on the back to strengthen it to keep it from sagging?
B) on the engine side - any one consider materiel glue and new black fire retardant materiel to renew that side?
C) I have sprayed mine with black grill paint I had to cover the color issues and i does look better - for a while..?
These are just some ideas I have had because my D1 is being kept at the most stock configuration I can handle and I know I am the exception.
Most have already been modified to the point of -- who cares about the liner..
But if these ever are to become a rare and favorable item years from now the stock ones will be the best to own.. I think..
Other ideas??
Old Jun 12, 2021 | 08:19 PM
stillruns's Avatar
The engine bay insulation foam isn't worth keeping if it's sagging or chewed up or whatever. You can buy new insulation foam and use the current liner as a template. Cut it to fit, buy new round clips and install. The original isn't going to affect the value of these vehicle. I am getting ready to do this exact thing myself. If anything, having a fresh piece of insulation foam under there will look much better than the original.
Old Jun 13, 2021 | 12:42 AM
Icannap1's Avatar
Just replace it. Purchased a roll from
Amazon.com: CSI 25070 Heat Shield Insulation: 4 ft x 6 ft: Automotive Amazon.com: CSI 25070 Heat Shield Insulation: 4 ft x 6 ft: Automotive
and glue it to the interior of your hood. You can then finish the edges with foil tape that is used for A/C ducting.
Old Jun 13, 2021 | 12:07 PM
disco96sd's Avatar
I used a new MBZ foam pad that is a very close fit - my original Landy pad attracted mice and now not a creature is stirring
this is the pad
Mercedes Hood Insulation Pad - Febi 1166820026
Old Jun 13, 2021 | 04:38 PM
Thanks.. I still struggle with this due to the aftermarket items looking so much like .. aftermarket products.
I really don't like the shiny metal look.
I have been looking for replacement felt or foam like material to cut in the shape of what I have but it's hard to find.
Will be nice to see what you come up with - please post.
Thanks
Old Jun 13, 2021 | 04:40 PM
Icannap1 - well done! very neat. I am still trying to stay away from the after market look.
But yours is one of the better jobs I have seen pic's of.
Old Jun 13, 2021 | 04:44 PM
this is the pad
Hey! That looks like a great idea.
It even seems like a better cost factor compared to aftermarket products.
Got a picture of the finished project? or the dimensions?
And can you / have you cut it to match the original?
Thanks
Old Jun 13, 2021 | 10:36 PM
jimvw57's Avatar
Originally Posted by Icannap1
Just replace it. Purchased a roll from Amazon.com: CSI 25070 Heat Shield Insulation: 4 ft x 6 ft: Automotive and glue it to the interior of your hood. You can then finish the edges with foil tape that is used for A/C ducting.
what type of adhesive did you use? my D1 has nothing on the underside of the hood...
Old Jun 14, 2021 | 01:22 AM
Icannap1's Avatar
I just removed the hood and placed it on a couple of moving blankets cleaned it with acetone then sprayed it with contact cement using a cheap HF spray gun once it was dry I pressed it in to the crevices beginning in the center and worked my way outward. Any overspray can be cleaned up with acetone once it dries. It's the same way I did the headliner.
Old Jun 20, 2021 | 11:40 AM
jimvw57's Avatar
This may sound like a basic question, but exactly what is the purpose of the insulation under the hood?? Keep the hood cool? keep the motor warm? sound deadening? lots of theory but no specific answer...
My 99 D1 is missing the under hood insulation and I see the hood flexing when I am at speeds and heavy winds.Could this be a contributing factor to my truck running hot when the temps are hotter out? My 97 had the insulation and I did not have the same problems
