Idle problem
Old Jul 17, 2017 | 12:59 PM
machinetech's Avatar
Unhappy Idle problem
97 land roverWhen taking foot off gas pedal rpms drop way down to the point when it wants to stall. No obd codes show up. Any help on what to check will be appreciated.
Old Jul 17, 2017 | 01:21 PM
hrhoward's Avatar
Throttle cable adjustment or IAC is my guess.
Old Jul 17, 2017 | 01:59 PM
whiskeynipple0088's Avatar
if you havent already
spray out the intake
de carbon the engine with seafoam
replace PCV hoses and clean the valves
did you use lower octane gas recently?
Old Jul 17, 2017 | 09:05 PM
99DiscoFlyer's Avatar
Also get your battery tested. Had the same happening to me last summer.
Old Jul 22, 2017 | 05:18 PM
ajnolin's Avatar
Just corrected a similar issue by cleaning IACV, clean the pintle shiny and bright but take care to not change its adjustment, and make sure you get in there and clean the bore. IACV pounds the oil coming in from the crankcase breather into asphalt, and can cause all sorts of idle weirdness, will be adding an oil separator
Old Jul 23, 2017 | 07:52 AM
WaltNYC's Avatar
Agreed. I went through it last summer. Eventually I needed a new IACV. the part itself can be found in an array of prices from $15 to $150.
There is a napa part number ($52) in the thread I started. Search should pick it up.
wick_60010
Nov 22, 2017 04:25 AM
KGN96discoSE7
Sep 23, 2017 07:23 AM
enigma_rjp
Jun 10, 2006 11:31 PM
westernsun
May 27, 2006 04:24 PM
russ00001
May 9, 2006 08:53 PM
