ignition key stuck and adible tone
Old May 22, 2014 | 03:50 PM
TOM R's Avatar
Default ignition key stuck and adible tone
Need help here, key will not turn all the way to remove and with key on there is always a steady tone from mfu
I did a search, tried disasembly of shifter handle to tighten the nut inside, no help there , the shifter is in park, the trans is in park, crawled under to check
Raining and need this fixed
Old May 22, 2014 | 05:56 PM
TOM R's Avatar
Also drivers door pin switch now inop and the dome lite turns off immediate when you open other doors
Guessing MFU is bad? I hear it click when I try to turn key to remove
Old May 22, 2014 | 06:52 PM
TOM R's Avatar
Ran MFU check, sequence ran as it should?.? Ideas?
Old May 23, 2014 | 09:55 AM
TOM R's Avatar
What is the difference between the auto and manual ignition tumbler? I have auto trans, but a spare manual tumbler
Old May 23, 2014 | 12:52 PM
TOM R's Avatar
http://texasrovers.org/e107_plugins/...opic.php?31345
Old May 23, 2014 | 12:53 PM
TOM R's Avatar
Texas Rovers: Forums / Discovery / Key stuck in ignition fix
Old May 23, 2014 | 05:11 PM
TOM R's Avatar
Well took off the column covers unplugged a white plug just above the key and now key comes out, the connector goes to the lite ring and ? But everything works so good for now till I have more time later
I do still have the audible tone with key on
Old May 25, 2014 | 05:29 PM
TOM R's Avatar
OK I sort of figured out the noise from mfu by mistake
I tried going into low and it will not move, now stuck in 4 hi, but pulled back on that shifter, sound stopped, push forward sound comes back, did this several times same results
So .... guessing it is an alarm saying you are not in 4 hi all the way but trans is in drive? Or hey dummy I will not let you out of 4 hi unless trans is in p/n?
Either way I have working diff lock but stuck in 4 hi, guess I should have gutted the plunger with trans out ugh
ImQuattro
May 1, 2014 08:36 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
8413b
Jul 27, 2007 07:20 PM
moneypit37
Nov 27, 2006 02:20 AM
Tayo
Sep 10, 2005 01:13 AM
