ignition light ring is always on
I just went to check mine because I had noticed that the other day also. But the light is off right now when I checked. I am going to assume that it should turn off and not stay on all the time.
The difference is that my truck does have electrical problems. I will keep an eye on it this week though.
I'm skeered of the dark, but I went out anyway and watched mine (97). It follows the dome lights, and when they time out and dim down the ring stays in step with them. So it is controlled by the Multi Function Unit (MFU), which is a plastic box on the back of the fuse panel under the dash.
Hi,
I just bought a 97 Disco and I am having the same problem with the red ignition cylinder light staying on all the time. Did you figure out what was going on? I haven't been able to find anything online about this other than your post. I am keen to get this sorted out.
Thanks,
Mark
Thanks,
Mark
