Im to try an e-fan conversion need help/info
Old Dec 27, 2010 | 08:50 PM
Spencerfitch's Avatar
Default Im to try an e-fan conversion need help/info
I can figure out the wiring and such
I can figure out a mount.
what I have no clue about is what size/type/brand/number fans to run.
are the CFM ratings really accurate? And how many do I need to match stock?
Old Dec 27, 2010 | 09:16 PM
two flex a lites for about 300$ with 2500 CFM enough? I got the dimensions and all
Old Dec 27, 2010 | 09:33 PM
COOTER-GUY's Avatar
I am sure that Rovers don't need much more cooling from the primary fan then a Jeep Cherokee they always want to run hot. I have along with many others used the fan off of a Ford Taurus anything from 96 up I believe has the dual speed single fans on them. That way the primary fan can run off a thermostat and you can manually engage the high speed side or even hook it up to come on with the AC. Usually pick one of them up for around $60 or so used and then a relay and adjustable thermostat at any Advance.
Old Dec 27, 2010 | 09:37 PM
Forgot
About the focus option
Old Dec 27, 2010 | 09:40 PM
COOTER-GUY's Avatar
Glad to help you out, hopefully save you a few bucks in the process
Old Dec 27, 2010 | 09:53 PM
thehun's Avatar
I want an E FAN so bad...
andytaylors
May 27, 2010 11:59 PM
geoman
Apr 17, 2007 01:08 AM
97DISCOIDAHO
Aug 30, 2006 02:40 AM
rebel1
Oct 7, 2005 09:41 PM
97 Disco
Apr 30, 2005 03:07 PM
