Insatalling Control Arm Bushings
Old Jul 12, 2010 | 03:04 PM
kenk's Avatar
Default Insatalling Control Arm Bushings
I will be doing my control arm bushings soon, and since I will be removing the cotrol arm and having a shop press the old out/new in, I want to do both arms in one shot.
If I put the front on jackstands, chock both back wheels front and back, will it be safe to remove both control arms at the same time?
Old Jul 12, 2010 | 05:59 PM
Long Haul's Avatar
If you have jackstands thatllvgo the whole way to the frame. As soon as you take the control arms off the front axle will have nothing but the shocks and springs supporting it. I recomend one side at a time so it wont throw your alignment off either
Old Jul 13, 2010 | 08:40 AM
antichrist's Avatar
A tall jack stand under both chassis side rails.
Two short jack stands under the axle.
Depending on what the shop is charging, now might be a good time to justify buying a 12 ton press.
http://www.northerntool.com/shop/too...6415_200326415
It's more, I'm sure, than what you'll be paying the shop, but you'll use it for a lot of other things too, like the trailing arm bushings which should be replaced too.
Things like: Installing hub bearings, R&R u-joints, R&R idler pulley bearing, R&R panhard rod bushings (should be done now too)....you get the idea.
Old Jul 13, 2010 | 08:54 AM
kenk's Avatar
Yea, i contemplated buying my own press, and really should. Seems like everything I get done is $20. The panhard bushings were already done($20), had them do the swivel bearings and bushings in the swivel *****($20), u-joints($20 a shaft). Cheated on the wheel bearings and used a drift to tap out the races and tap new ones in. I coulda just about paid for one by now. If only my nearest harbor freight wasn't an hr away.
Old Jul 13, 2010 | 08:59 AM
Spencerfitch's Avatar
man i had no clue it needed a press
Old Jul 13, 2010 | 09:04 AM
kenk's Avatar
I've heard in extreme circumstances, you can remove bushings without a press by cutting or burning the rubber center out, then use a hacksaw blade to cut through the outer ring of the old bushing, but at $20/arm, I'll gladly pay to miss all that fun
Old Nov 4, 2013 | 11:35 AM
Mattvail's Avatar
I need this done as well . Take it to any shop?
Old Nov 4, 2013 | 11:44 AM
fishEH's Avatar
Why bother with jackstands at all???? Leave the tires on and chock all the wheels. It won't go anywhere, trust me.
Get a quote from a shop. As mentioned, it might be a better investment to buy a Harbor Freight press.
Old Nov 4, 2013 | 12:15 PM
TOM R's Avatar
The 20 ton hf press works great, also get the master adapter set for their ball joint press, you will need all this to do the rear ball joint eventualy
Old Nov 4, 2013 | 01:18 PM
Mattvail's Avatar
Thanks for the advice
