Installed Treadwright Gurard Dogs 265/75
Old Apr 15, 2011 | 02:07 PM
AKdisco's Avatar
Looks SHARP man!!. I went with some 245 75 16 MTR's with my 2" lift and its great.............however I still want bigger. Rims look sharp. I just painted my rims black last weekend and they turned out AWESOME. I skuffed rims with steel wool...............Primered them with 2 coats grey fast drying primer...........Then shot them with 4 coats of SEMI-GLOSS Rustoleum Black spray paint.......then 2-3 coats of Clear coat spray paint after that was dry. I did this WITH tires on truck, they came out awesome. My truck now officially has NO shiney shi* on it. The black rims with the black painted Hood Bonnet and the black bumpers and door handles/trim/roof rack and then with the red paint looks sharp.
Old Apr 15, 2011 | 08:54 PM
bmxermike's Avatar
Originally Posted by turf63
Two questions. Are you lifted at all? Appears to be. 2) what'd you use to paint your rims?
Yes I have terra firrma HD springs and shocks installed. They are way too stiff, that's why my tires don't rub.
I used some primer and paint from home depo, I forgot the brand but it was the cheapest stuff I could find.
Old Apr 15, 2011 | 09:00 PM
bmxermike's Avatar
Thanks AKDisco.
I was thinking about 245/75 because I was afraid to go to big and run into problems with gearing and being able to flex. But I am very happy with the size.
The power loss is definatly noticeable and re-gearing would be ideal for these size tires, but money is tight and it drives fine for now.
Old Apr 16, 2011 | 07:47 AM
hilltoppersx's Avatar
agreed the HD TF kit is harsh if you don't have any heavy bumpers front and rear and a winch fitted. once you get that weight that it's craving it should ride normal.
Old Apr 16, 2011 | 10:46 AM
bmxermike's Avatar
Bumpers are going to added soon. Once school gets out I'm going to start building them. Hopefully that solves the problem.
Old Apr 18, 2011 | 06:42 PM
thehun's Avatar
Thanks AKDisco.
I am noticing this now with 265 as well...however she is PERFECT in 4LO lock when hitting the trails..
taylor15
Sep 17, 2014 04:50 PM
Rover_Hokie
Tires
Jan 28, 2014 06:44 PM
Sarge103
Mar 5, 2013 08:03 PM
honden-coach.nl
Defender
Nov 5, 2012 06:02 AM
thehun
Mar 13, 2011 12:37 PM
