Installing D1 Kickdown Cable in Transmission
Old Apr 19, 2014 | 06:28 PM
Pikulone's Avatar
Default Installing D1 Kickdown Cable in Transmission
What quick steps can I take to install the kickdown cable in the transmission while it is on the car, 96 D1. Does this require dropping the pan and draining the fluid? Access from the side is limited.
Old Apr 20, 2014 | 11:11 AM
tuercas viejas's Avatar
Yes it means dropping the pan!
You can fiddle it into the case and around the quadrant with the pan sat on the cross-member.
Start at the transmission end and fit it last at the throttle linkage.
Have a cuss box on hand --you will need it!
Best of fiddling.
T/V
Old Dec 20, 2014 | 01:27 PM
dsmeddy's Avatar
Other than the cable breaking, why else would it need to be replaced??? My '97 sshift points are funky. I keep playing with cable
philwarner
Mar 30, 2017 11:16 AM
raro88
Jul 11, 2014 10:19 AM
scottmb23
Dec 27, 2013 05:08 PM
ajnolin
Nov 24, 2013 09:29 PM
Jimbo
Aug 9, 2005 11:09 AM
