Interior light issue
Old Oct 5, 2012 | 04:53 AM
wabuson's Avatar
Default Interior light issue
1994 Discovery
So my dome light wont turn on when switched to ON. When left in the middle it turns on and off when the doors open and close. Even dims out appropriately. Any ideas?
Old Oct 5, 2012 | 11:52 AM
Ground lead on switch at dome light. The fades out means your multifunction unit is OK.
Old Oct 5, 2012 | 03:30 PM
wabuson's Avatar
In theory replacing the light would solve this problem then?
Old Oct 5, 2012 | 04:16 PM
If it is doing above, then bulb is OK. The mechanical dome light switch also applies a ground to the bulb in the "ON" position, this will use a short black wire from the switch to a bolt on the metal of the truck. If switch is bad or wire is broken, the "ON" position won't work.
RWAC94
LR2
May 3, 2015 12:29 AM
usnavylt
LR4
May 1, 2015 03:40 AM
jdwilks
Aug 27, 2014 10:59 AM
Kalel
Mar 29, 2012 08:31 PM
JKK
Oct 12, 2005 11:32 PM
