Irregular Air/Fuel Intake Fibrillation
Old Feb 17, 2021 | 07:07 PM
  #21
nzajg's Avatar
I missed answering your question. The rpm meter fluctuates up/down with the condition. Cheers Tony
Old Feb 24, 2021 | 01:30 AM
  #22
CantComplain's Avatar
Originally Posted by nzajg
Not the fuel pump relay as I'm reading a constant 38psi at the fuel rail.
I'm not too concerned that you moved past the relay, but can you confirm that you're seeing 38 psi when you have the fibrillation? You're dealing with an intermittent issue, so I would expect everything to look perfect when it's idling or not running with the ignition on. If there are identical relays elsewhere, it would be simple to swap them to eliminate it from suspicion (unless you're confirming you see the fuel pressure maintained during an episode, but even then TBH).
I'd also check out that ground from the ECU that's labeled "earthed via park/nuetral switch" based on the other issue you had. Wouldn't hurt to shine up all the connections there and make sure the switch is operating correctly.
Old Mar 3, 2021 | 05:08 PM
  #23
hrhoward's Avatar
Sorry for delay in responding.
Ok, regarding the fluctuation in rpm, how much when it's happening? Another question, does it only happen in 4th/TV lock-up or will it happen in 1-3?
Old Apr 14, 2021 | 06:19 AM
  #24
WaltNYC's Avatar
vss rebuild
File Type: pdf
Intestinalworm
Jun 27, 2018 05:59 AM
mattmannz
Nov 24, 2017 12:40 AM
chelvey@helveyconsulting.com
Jun 21, 2016 07:43 AM
Tony Morrish
Apr 17, 2012 04:03 PM
NM-DiscoDuck
Jul 13, 2009 08:59 PM
