Jacking Up Transmission
Old Oct 21, 2021 | 02:05 PM
ononomos's Avatar
Default Jacking Up Transmission
I’m about to change my rubber transmission mounts, which requires lifting the automatic transmission from where it sits in order to get the old ones out and put the new ones in.
Is it as simple as putting a floorjack underneath the pan/transfer case and cushion it with some 2x4s and jacking it up?
What should I disconnect or remove in order to not damage anything?
Is there even enough room?
Information on this is slim compared to changing engine mounts, which I have done. Only the engine has no ceiling, other than the truck’s hood, so it was simple to jack up.
Old Oct 21, 2021 | 07:21 PM
JohnZo's Avatar
Well, Onon, this doesn't answer your question directly, but if I were to do those (I'm not) I might just pay a mechanic and have them done in an hour. They do that type of work all the time with all the right tools (and tricks).
Old Oct 21, 2021 | 07:42 PM
Best4x4's Avatar
You can just place a block of wood under the TC and support it with a bottle jack. Lift it high enough to remove the mounts and re-install them.
ononomos
May 27, 2021 07:01 PM
Lisa Bunch
Apr 1, 2019 09:39 AM
Daedrix
Sep 26, 2016 01:40 PM
Alex_M
Nov 11, 2014 07:21 PM
04duxlr
Sep 22, 2014 07:38 AM
