Just found out that I've been using Dex Cool.
Old Aug 10, 2011 | 04:32 PM
collin Barrows's Avatar
Default Just found out that I've been using Dex Cool.
Was working in the garage and noticed that I have been using dex cool antifreeze. How screwed am I? Also what antifreeze works with rovers?
Thanks Collin
Old Aug 10, 2011 | 04:45 PM
photocrimes's Avatar
Most people will tell you to change it for the green stuff. I run dex and have never had an issue. You have to change it and keep the system free of air.
Hot topic, get ready for the fireworks.
Old Aug 10, 2011 | 04:46 PM
Chris-bob's Avatar
I like fireworks...!!!!
Dexcool is not as forgiving towards lack of maintenance as the "green stuff" is. You will not kill anything using Dexcool as long as you monitor it's conditions regularly and change it when needed.
Old Aug 10, 2011 | 05:00 PM
wheelgarage's Avatar
GM = Dexcool.....go figure.
Old Aug 10, 2011 | 05:04 PM
We won't tell anyone if you change it now and burn the old containers in the yard as an offering to the lesser Rover gods.
Old Aug 10, 2011 | 05:23 PM
Street Wolf's Avatar
Put green coolant in it, this isn't just a "rover thing" kind of issue.
Old Aug 10, 2011 | 05:47 PM
Smile
Hahahaha, I'm going to do an oil change on my dads rover and my rover, so mine as well drain the dex and use the "green stuff". What is the "green stuff" and can i get it at auto zone, advance pepboys?
Thanks for all the input
Old Aug 10, 2011 | 05:58 PM
discomedic4's Avatar
Good ole prestone antifreeze is fine. That being said my wife's SAAB does just fine with dex.
Old Aug 11, 2011 | 12:59 AM
Chris-bob's Avatar
According to AllData...
Engine coolant Special Blend Ethylene Glycol Use an ethylene glycol bases anti-freeze (containing no methanol) with non-phosphate corrosion inhibitors suitable for use in aluminum engines to ensure the protection of the cooling system against frost and corrosion in all seasons
Old Aug 11, 2011 | 04:13 PM
Yeah....believe that!
Back in the days, I tore down a rotary engine that I got for free. I found that it had a nice hole from from the water passage, in the aluminum housing. The owner of that engine never replaced the coolant.....the water turn sooo corrosive it ate it alive!!!!
