Keep on Blowing Fuses...I'm Stumped
I keep on blowing the 15amp fuse for my blinkers and it's driving me insane. The strange thing about it is that I also lose my brake lights when the fuse goes. Here are the symptoms
The brake lights shouldn't have anything to do with the signals, correct? My thought was that the only time that they may be connected is in the trailer harness so I removed the plug in harness at the back of the vehicle. I also remove my stereo completely, as the previous owner installed an aftermarket unit and the wiring was rather iffy looking. I checked the blinker bulbs/connections at all four corners and nothing seems out of the ordinary. Any other suggestions?
- fuse blows sometimes only minutes into my drive (but could also last 1hr + drives)
- Lose all signals (front and rear) and brake lights
- I *think* it happens when I reach to use the signals to turn right
- I don't see any other patterns or notice that it happens when using a certain combination of things
Ah l, thought all D1's would be the same but it's a '96. Hazards work normally when the fuse is still goos.
I'm also beginning to think that my problems may be water related. It's been dry here for a few days which leads me to believe that one of my blinkers is probably filling up with water and shorting when it rains
You can check it visually. The white plastic where the blades are will be heat deformed and brown. The offending blade will be burned, darker than the others. I'll have to go through the wiring diagram to see which wires do what so you can check em with a meter while flipping the turn signal switch.
I just cleaned up the internal contacts on mine and cleaned up the blade and connector and that was good enough for the switch to work properly.
