Blowing ECM fuses....
Old Jun 22, 2010 | 07:21 AM
SC Rover's Avatar
Default Blowing ECM fuses....
Turns out that a previous owner had put a 20A (supposed to be a 10A) fuse in the the ECM system, and it finally blew the other day. Now I can't turn the key without blowing the replacement fuses I put it there, I even tried a 30A to see if that would work, but it didn't.
I assume that a wore somewhere has been slowly burned or broken through and it has grounded the entire system. I was wondering if anyone had any other thoughts, problem areas I should check, etc.
Thanks in advance!
Old Jun 22, 2010 | 07:55 AM
http://www.roverlandparts.com/discov...le-becm-1.aspx
Then get it reprogramed.
Old Jun 22, 2010 | 07:59 AM
kenk's Avatar
unplug the harness to the ecu, then turn the key on and see if you blow a fuse. yes-wiring problem. no-internal short in ecu
nahtanoj
Nov 14, 2013 05:02 AM
1998Disco1
Jul 30, 2013 08:33 AM
B.Young
Mar 30, 2011 11:11 AM
OxyCoRover
Jan 27, 2008 09:56 AM
The Capstone
May 11, 2006 12:57 AM
