Key Stuck in Ignition 1996 Discovery
Old Feb 10, 2022 | 09:04 AM
chandlerhayes01's Avatar
Well its definitely in park. i have went through the gears, wiggled the key, sprayed lubricant, check fuses, push, pulled, and all of the above. I read somewhere where it could be the shifter cable that needs to be adjusted. That is the next thing i plan on looking into. Someone has already gone through and messed with the wiring (im assuming to bypass the alarm?). I will probably break down and buy the new cylinder. The issue i see with those are they all say they are for manual transmissions and not automatics. so i am at a loss when it comes to that.
Old Feb 10, 2022 | 12:09 PM
Best4x4's Avatar
Remove it from the column and you can truly inspect it.
Old Feb 10, 2022 | 08:26 PM
problem solved! the new key i had made was not allowing the key to push all the way in. I used a small screw driver to push the cylinder in and turned the key. key turned to zero and came out. Went in the shop and took a sanding disc and filed down the key so it is able to push in all the way. Presto! everything works great.
thanks for all the help
cheers
chandler
Old Feb 10, 2022 | 08:48 PM
Best4x4's Avatar
Glad to hear you got it taken care of
Old Feb 14, 2022 | 07:32 AM
jimvw57's Avatar
Not sure where you found an ignition switch that inexpensive. The ones I found were 5x that for an automatic and about 2x that for a manual trans. It pays to shop around.
But then I needed the electrical part as well as the keyswitch part. Previous owner had really butchered it and chopped up the wiring.
Old Feb 14, 2022 | 10:07 AM
stillruns's Avatar
Very interesting solution. Glad it worked.
swissarmychainsaw
May 1, 2021 02:41 PM
Jadamay
Jan 28, 2017 08:34 AM
FredMcIntire
Dec 24, 2015 09:31 AM
elpapisf
Apr 18, 2012 06:19 PM
northon11
Jan 11, 2010 09:16 AM
