Leaky Front Seal??
Front seal is fairly easy.
The crank bolt is 200ft/lb or so, I used old serp belt thru' 1-1/2" pipe (18" long?), choked on pulley like necktie.
Then I vicegripped *** end, propped pipe against frame, put my 'lil 3' helper on breaker bar to remove bolt.
Pulley slides right off, pull seal, tap in new(greased), reverse order to re-install.
luck,greg
luck,greg
yloDiscoII
02-10-2010 10:03 PM
