Sponsored by: CARiD
leaky NEW front axle seal
Old May 23, 2015 | 01:16 PM
winx's Avatar
Default leaky NEW front axle seal
I recently replaced front hubs and thought it wise to replace axle seals while I was in there. The driver's side leaked but the passenger side didn't. After reassembling everything I found the pass. side leaking. I figured I mussed somethong up and replaced again with another new one. This one leaks too and I know it is installed correctly. I did some forum research to find I am not the first or only. I found the right diameter circlip to use as a spacer. The thickness is 2mm. I would prefer it was 1mm. Any thoughts regarding my proposed spacer fix? And to the 2mm issue?
Old May 26, 2015 | 06:55 AM
TOM R's Avatar
Blow out the vent line, could be building pressure
Old May 26, 2015 | 02:22 PM
winx's Avatar
Thanks, I tried that and it is clear, unfortunately.
Do people just keep putting in new seals until one works?
Old May 27, 2015 | 06:12 AM
drowssap's Avatar
I thought i saw a post last week about an improved front axle seal?
Old May 27, 2015 | 09:13 AM
winx's Avatar
I'll search, thanks!
Old May 27, 2015 | 11:50 AM
winx's Avatar
I see I misinterpreted the cause of seal leak- not a positioning issue, but the seal inner diameter. My spacer fix would probably just have created another problem. But still no solution- did anyone ever find a supplier with correct size seal?
Old Aug 23, 2023 | 04:22 PM
Broken08's Avatar
Any updates? Same problem
FlyingZebra34
Apr 18, 2014 02:00 PM
outdoor7or24
May 21, 2012 08:34 AM
jmason
Aug 31, 2011 08:43 PM
Silver_Slug
Aug 23, 2010 02:35 PM
nickd503
Sep 11, 2009 11:03 PM
