Leaky Front Seal??
Old Aug 23, 2010 | 07:59 AM
Silver_Slug's Avatar
Default Leaky Front Seal??
i believe my truck has a leaky front seal. Has anybody done this before? Had it happen?
Old Aug 23, 2010 | 10:54 AM
Jull's Avatar
Which seal?
Old Aug 23, 2010 | 12:01 PM
engine front seal??? Doesn't look like its coming from the heads or the valves. Looks like its in the front of the engine and is blowing back when i drive.
Old Aug 23, 2010 | 01:38 PM
AK Rover's Avatar
Are you meaning the crankshaft seal in the front cover? Where are you seeing oil on the engine? If it is coming from the front main seal around the crankshaft the oil will strictly be at the bottom of the engine and on the oil pan. Have you retorqued the valve cover bolts?
Old Aug 23, 2010 | 02:35 PM
greg409's Avatar
Front seal is fairly easy.
The crank bolt is 200ft/lb or so, I used old serp belt thru' 1-1/2" pipe (18" long?), choked on pulley like necktie.
Then I vicegripped *** end, propped pipe against frame, put my 'lil 3' helper on breaker bar to remove bolt.
Pulley slides right off, pull seal, tap in new(greased), reverse order to re-install.
luck,greg
winx
Aug 23, 2023 04:22 PM
FlyingZebra34
Apr 18, 2014 02:00 PM
outdoor7or24
May 21, 2012 08:34 AM
yloDiscoII
Feb 10, 2010 10:03 PM
nickd503
Sep 11, 2009 11:03 PM
