leaning to left?
Old Aug 22, 2013 | 07:25 AM
  #21
CUpgt's Avatar
I just set them next to each other. Taller one goes on the DS
Old Aug 22, 2013 | 07:48 AM
  #22
dansgt's Avatar
No way to tell on there? I don't remember a difference in height between the 2.
Old Aug 22, 2013 | 08:01 AM
  #23
fishEH's Avatar
Originally Posted by dansgt
Chances are good I need to read both with my luck. Where are they marked so I can see before I tear it part again?
IDK, they were marked somewhere on the coil. There's probably a part # and at least one should say "DS" or "PS".
Old Aug 22, 2013 | 09:16 AM
  #24
dansgt's Avatar
I'll look again. Don't remember anything or any difference, but could be wrong. Now thinking about it though, front right was a lot more a pain in the *** to get in then left, that could very well be why...
Old Aug 22, 2013 | 05:46 PM
  #25
dansgt's Avatar
So they are marked, and maybe I did notice cuz the 3 of the 4 I found marks on, and are in the correct spot. Unless they are marked for a rhd truck?
Old Aug 22, 2013 | 05:48 PM
  #26
jafir's Avatar
So they are marked, and maybe I did notice cuz the 3 of the 4 I found marks on are in the correct spot. Unless they are marked for a rhd truck?
Driver's side is the side the driver sits on, whether LHD or RHD. That's why they didn't mark them left and right.
Old Aug 22, 2013 | 05:56 PM
  #27
dansgt's Avatar
So why would it be leaning then? I measured the front springs and was almost 1" difference in compressed length side to side. Didn't measure the rear yet.
Old Aug 22, 2013 | 06:20 PM
  #28
CUpgt's Avatar
You dont have both rears on one side and both fronts on the other do you?
Old Aug 22, 2013 | 06:37 PM
  #29
dansgt's Avatar
No, wouldn't work anyways if both left said Ds an both right PS. Only opened one box at a time anyways, so no chance to mix up front to rear.
Old Aug 22, 2013 | 10:28 PM
  #30
Mightym's Avatar
I have some OME Hd springs waiting to be put on. They have recently been re-powder coated, so the tags are no longer on them. I was wandering if the taller rear spring would go on passenger side since that is where the spare tire is. Then the taller front on driver side to compensate for driver. Any info would be appreciated.
Thanks, Ron
