LED clock bulb with holder -here
Old Feb 16, 2013 | 08:44 PM
jdogg's Avatar
Default LED clock bulb with holder -here
Not sure if its been mentioned here or not. If so I haven't seen it. But I needed to replace my clock bulb and wanted an LED so it wouldn't burn out again. I was just looking for a bulb to stick in the old holder but I ran across these on ebay and they are an exact fit!!! I had to relax the little metal tabs a little to keep from tearing up the contact points on the clock, but other than that it works perfect. I ordered several different colors and ended up using the blue.
1 x 5mm LED T5 B8 5D 2721 286 Yellow Auto Interior Dome Light Bulb Lamp Bulbs | eBay
Old Feb 17, 2013 | 06:19 AM
Good to know. May your Rover last long enough to burn out another clock bulb!
Old Feb 17, 2013 | 09:48 PM
bcbp's Avatar
Sweet! Will white give the original color, or would that be green?
Old Feb 18, 2013 | 10:50 AM
SSL9000J's Avatar
Wait... the clock lights up??!
Old Feb 18, 2013 | 11:25 AM
jdogg's Avatar
I didn't try the white, but I did try a green and it looked pretty original.
Old Feb 28, 2013 | 09:17 AM
bigbadwolf1966's Avatar
Cool ! thx
Old Mar 3, 2013 | 10:49 AM
RichardBoutwell's Avatar
I was just thinking the SAME thing. Adding this to the list...
Old Oct 1, 2013 | 02:53 PM
jalodge's Avatar
I didn't know the clock lit up either. What is the original bulb color?
Old Oct 1, 2013 | 06:41 PM
nuclearw's Avatar
if you never knew it lit up does the original color really matter? lol
Old Oct 2, 2013 | 09:04 AM
gprtech's Avatar
The original bulb is clear, but there's a green filter inside the clock.
