Lesson learned, don't ignore vibrations...
Old Feb 13, 2017 | 12:04 PM
FLA Rover's Avatar
Default Lesson learned, don't ignore vibrations...
So what I thought was my brakes starting to go along with a wrapped rotor, turned out to be something totally different! At no point did it seem like a bad u-joint that is until this happened...
Old Feb 13, 2017 | 01:45 PM
jastutte's Avatar
is that the only damage? didn't hit your transmission or exhaust?
Old Feb 13, 2017 | 02:10 PM
FLA Rover's Avatar
Nope, scuffed up the heat shield on the catalytic converter and nothing else. I had just pulled out of a parking lot for cross a street I to a turn lane.
Old Feb 15, 2017 | 03:00 PM
ihscouts's Avatar
And do I see any grease? Uh no.
Old Feb 15, 2017 | 05:25 PM
Shiftonthefly1's Avatar
You got really lucky
Old Feb 16, 2017 | 02:18 PM
ROB99DISCOSD's Avatar
First thing I noticed too. Looks dryyyyy.
​​​​​​​Sucks nonetheless.
Old Feb 20, 2017 | 07:23 AM
geek_IM's Avatar
Why did you think it was a warped rotor? I'm not busting your stones, but if you can provide some more symptom info maybe it can help someone else.
In my case, it was a persistent vibration felt through the steering wheel and eventually shook the whole truck, I assume when all the needle bearings fell out. It would be worst on heavy acceleration from a dead stop. It was most pronounced between 35-40 mph, and would smooth out at highway speeds. It would disappear in "float" conditions ie foot off the gas at speed. Interestingly, the symptoms front vs. rear were so similar that I removed the relatively fresh front shaft to examine it before realizing that I had wasted my time and the rear one was the culprit.
And I gotta say, I have a lot of respect for the design of the yokes. I had to beat the living **** out of them with a 10 pound sledge to get what was left of the universals out of them. How long did you drive it to get those results?
Old Mar 13, 2017 | 07:16 PM
notny41's Avatar
holy crappers! I had a vibration that actually kicked my 2wd/4wd shifter into neutral a few times - same deal but mine didn't bust apart - it was just really really loose - like the bearing parts had fallen out of the cups... replaced mine and it was good. probably should get under there with the grease gun again tho now - it's been a little while
wheelgarage
Jul 21, 2023 02:27 PM
partsguru
Jul 16, 2018 06:47 PM
slowfiveo
Off Topic
24
Aug 21, 2015 07:26 PM
FLA Rover
Aug 19, 2013 11:19 AM
photocrimes
Mar 16, 2011 05:30 PM
