Lockers
Old Sep 16, 2011 | 12:03 PM
Chris-bob's Avatar
Default Lockers
Yes, I did a search first.
Is ARB the only locker available for the D1?
Cause if it is, that sucks.(I hate air lockers.)
Old Sep 16, 2011 | 01:17 PM
jafir's Avatar
for example:
Detroit Locker Part EAT187SL173A - Detroit Locker Differential
Old Sep 16, 2011 | 01:58 PM
Long Haul's Avatar
Detroit, Ashcroft, KAM, ARB, theres a few others out there too. The KAM is electric activated similar to ARB's but no air lines. The Ashcrofts are air operated. Detroit is the only non selectable locker that I know of and then theres TruTracs but I consider that more of a limited slip then a locker. Also DII's and Defenders all take the same diff if that helps broaden your search a little.
Old Sep 16, 2011 | 08:59 PM
Jake1996D1's Avatar
Brian knows his lockers. Lucky 8 has all of these too if you want to read about them and compare prices
Old Sep 17, 2011 | 12:04 PM
Jake1996D1's Avatar
I am most likely going to pick up a TrueTrac for the front and a Detroit for the rear.
Here's a good article
Detroit TrueTrac® Differential
Old Sep 18, 2011 | 12:40 AM
Chris-bob's Avatar
I keep forgetting to look at Lucky8. Thanks for the info.
skatelove303
Jun 20, 2009 08:10 PM
Fivespddisco
Member Group And Special Buys
Mar 1, 2009 06:46 PM
roverwoody
Sep 21, 2008 03:57 PM
andrewmcoffin
Apr 11, 2008 07:33 PM
CrimeScene
Jan 30, 2006 06:12 AM
