Losing oil quite quickly after head gasket job
Old Feb 26, 2023 | 08:29 PM
Reza27's Avatar
Default Losing oil quite quickly after head gasket job
I recently did my head gaskets and now I am going through quite a bit of oil. I dont see it leaking on the ground so I assume its getting into the combustion chamber somehow. I also had valve stems done and the heads passed a vacuum test from the shop that resurfaced them.
any advice on how I should troubleshoot this?
Old Feb 26, 2023 | 08:49 PM
JohnZo's Avatar
My first suspect is valve stem seals. How do the plugs look?
Old Feb 27, 2023 | 11:41 AM
Reza27's Avatar
I pulled 4 of the plugs and they were all really wet
Old Feb 27, 2023 | 08:47 PM
JohnZo's Avatar
Oil on the intake valves should be easy to see but will require some disassembly of the intake apparatus.
One of my early rebuilds burned a quart every 1000 miles. Turns out I did not seat the valve stem seals properly.
Old Mar 1, 2023 | 08:38 AM
Reza27's Avatar
I pulled it apart but im not sure how to tell if they are in there properly or not. Should I take the whole intake off to try to see from the intake ports on the top of the heads?
Old Mar 1, 2023 | 07:22 PM
JohnZo's Avatar
Check if they lift up easily. Just pry up with a screwdriver or such.
If you take off the intake manifold, you can see the valves directly. Thanks for the photo.
Old Mar 9, 2023 | 01:45 PM
Reza27's Avatar
just got back around to messing with this. the valve stem seals dont seem to be moving with a screwdriver. I've got a friend who has a tiny camera with a light that im gonna push through to the intake to see if I can see oil later today
was going through all the stuff left from the head gasket kit and I found these 8 big seals but I never saw any in the block when I tore it down. were these needed somewhere and I somehow missed them entirely? I looked through a whole bunch of atlantic british and a few other sites and cant seem to figure out what the heck they are and I dont see them in any diagrams in the RAVE either
Old Mar 9, 2023 | 11:29 PM
JohnZo's Avatar
So if I follow the clues: Rover V-8, about the size of a fuel injector?????
Richard Gallant
Mar 7, 2020 03:05 PM
pinkytoe69
Apr 20, 2013 07:22 PM
legendary
Mar 18, 2013 10:08 AM
Gordon Bombay
Dec 15, 2009 11:03 PM
fatboyx9
Aug 26, 2008 07:16 PM
