low fuel pressure
Old Mar 8, 2011 | 09:44 PM
Dodger's Avatar
Default low fuel pressure
Well I checked my fuel pressure, and it is only 20psi at idle. The book calls for 37psi. I clamped off the return line, so I am guessing it is not the regulator, but the fuel pump. Any suggestions before I order a new one?
Dodger
Old Mar 8, 2011 | 10:59 PM
UpChuck's Avatar
Has the filter been changed recently?
Old Mar 9, 2011 | 01:45 AM
Chris-bob's Avatar
Dodger
Can you point out where it says 37psi at idle? I could only find a spec for key on engine off psi...I searched the RAVE(guess not hard enough) last night for over an hour.
Old Mar 9, 2011 | 07:19 AM
Dodger's Avatar
Filter is new, here is the specs from page five in the information section:
FUEL SYSTEM 3.9 V8i
Fuel system type .................................................. ............ Lucas 14CUX hot wire system electronically controlled
Fuel pump-make/type .................................................. .... ACX delco high pressure electrical, immersed in the
fuel tank
Fuel pump delivery pressure ............................................ 2.4-2.6 bar (34-37 lbf/in2)
Fuel filter .................................................. ........................ Bosch in-line filter ’canister’ type
the truck appeears to run fine, it just takes for ever to start.
Old Mar 9, 2011 | 09:32 PM
Dodger's Avatar
Ok, so after a new fuel pump I now have 36 psi at idle. Runs much better now!
Timebus
May 4, 2011 07:34 PM
bgarrett
Freelander
Dec 18, 2009 06:32 AM
leadfoot
Sep 13, 2009 09:51 AM
paul1454
Mar 6, 2009 05:10 PM
discoken
Nov 4, 2008 12:39 AM
