Low to Mid Speed Bucking - CDL Applied and Open
Old Jan 4, 2020 | 11:33 AM
_ExpeditionMan's Avatar
Default Low to Mid Speed Bucking - CDL Applied and Open
All,
I've been chasing down some rather frustrating issues with my 5spd D1. I regularly encounter bucking in 1st-3rd gear in high range when transitioning from on throttle to off throttle. This is always accompanied with requisite engine fluctuations (100-300 RPM). I.e. off throttle down RPM, buck, up RPM, buck, down RPM, buck... repeat until brakes applied or declutch. A solid clunk from the front end diff or transfer case (really tough to tell which) is heard as well.
This issue is exacerbated in low range with the diff locked. In fact it makes driving over difficult terrain very frustrating as I am constantly having to declutch to avoid this back and forth rocking motion. I know the consensus is usually driveline play, however the diffs and transfer box were recently replaced with known good units. Same with the axle flanges. All the splines looked good. The output shaft on the R380 looked perfect.
The truck is a pre-AEL '96 5spd. I'm wondering if some or most of this issue is due to the engine RPM changes. For example, occasionally I can replicate an engine surge by idling forward in first gear, high range no CDL, (no gas applied) and then smoothly declutch. The engine will rev up to ~1200 RPM for several seconds and then slowly settle down to regular idle speeds.
I've seen a TSB related to closed throttle engine management (see here) posted on DWEB but it looks to be for '97 model years which are AEL only.
In summary, thought I had driveline issues but wondering if I have an engine management problem. Looking for advice troubleshooting
Old Jan 4, 2020 | 12:44 PM
AI surging idle would definitely cause bucking. Just like tapping on your gas pedal would as well. I would sort that then search out the clunking
Old Jan 4, 2020 | 01:07 PM
Any suggestions on how to troubleshoot something like this? I've monitored the TPS during these situations and it is not fluctuating when off throttle. What else to look at?
Tristan Stumpf
Jan 11, 2020 06:40 PM
bull907
Dec 16, 2019 04:27 PM
FlyingZebra34
Range Rover L322 (3rd Gen)
Aug 7, 2019 05:34 PM
norseman73
Sep 27, 2018 07:32 PM
racerxnet
Dec 5, 2012 12:00 AM
