Low oil pressure - finally fixed!
Old Jan 26, 2026 | 09:56 AM
Ozark4WD's Avatar
Default Low oil pressure - finally fixed!
As you may remember, I was chasing low oil pressure for some time. On Castrol 10W40, my hot idle was at 15psi, sand only at 32psi at 2500 rpm (should be almost 40psi per book). I changed oil pump, tried different oils, played with pressure relief valve - all standard things you want to do - nothing.
Finally, when i was tackling head gasket change this previous week, I also went with the radiator change. When I pulled out oil lines from the radiator, thick black sludge started coming out from the radiator fittings...I flushed hoses and put the new metal radiator in. Finished the job and bam! Pressure is slightly above 41psi at 2500rpm!
Now, it could be something to do with the head gasket, but i have a feeling that oil cooler inside that old radiator was the problem, especially because of the history of this truck...So while some of you maybe chasing low oil pressure gremlin, don't forget to check radiator too...
Old Jan 26, 2026 | 12:53 PM
Harvlr's Avatar
Oh wow, i wouldn't have expected that to cause low oil pressure. I'm glad you got it figured out.
Old Jan 26, 2026 | 03:58 PM
Ozark4WD's Avatar
Yeah, it wasn't on my "possible reasons for low oil pressure" bingo card either, ha!
rhunt7
Jul 21, 2014 11:16 AM
rewi9d
Apr 12, 2012 06:12 PM
kman35ca
Nov 26, 2011 11:05 AM
cathaan
Mar 12, 2010 09:45 AM
aerokurt
Dec 3, 2006 06:00 PM
