Lucas Gear oil
Old Dec 12, 2013 | 05:28 PM
wrongway1's Avatar
Default Lucas Gear oil
Quick question... I see the RAVE says the transfer case takes GL-4 oil. The only GL-4 oil I can find in this God forsaken town is Lucas Synthetic 75-145 GL-4/GL-5. Is that okay for the DI in a pretty cold climate?
Old Dec 12, 2013 | 10:35 PM
ihscouts's Avatar
I'm using AMSOIL Severe Gear 75W-90 for the tc, axles/swivels. Worth every penny in the single digit degree weather and in summertime heat. Most will give their opinion on cost but I don't care, it's my truck not theirs and I get 18mpg even in the winter.
Lucas actually failed a few tests I found rather important like viscosity shear testing. Hey, if it's all you can get then I guess your stuck with it. 75W is rated for -40 and with it being synthetic it will not become a liquid brick. Unless someone lives in a severe cold clime they have no opinion to share with me about synthetics.
Old Dec 12, 2013 | 11:09 PM
Rover_Hokie's Avatar
I am running the Amsoil gear oil as well on my D2, and their oil in the engine as well.
Old Dec 13, 2013 | 10:16 AM
wrongway1's Avatar
Oh, fear not... I am not afraid to pay for the best. I cannot find AMSOIL anywhere here, so my local choices are the Lucas or Royal Purple, but they are both 75-140 weight. The 140 sounds really thick; the high here is 19 today, and it's not even winter, so I am concerned that even with synthetic, the weight of the oil & forthcoming below zero temps may not be a good match. Perhaps I need to think about doing the 75 mile trek to the city to find something.
Old Dec 13, 2013 | 10:31 AM
jafir's Avatar
The 140 is after the oil warms up.
To make multi-vis oils they take a lower viscosity oil and add polymers to it that keeps it from thinning out as much when it warms up. So for example 75w140 starts out as close to a 75 oil and then only thins down to what a 140 weight oil would thin down to at normal operating temperatures. Normally 75 would thin down even more at temp.
Old Dec 13, 2013 | 12:51 PM
wrongway1's Avatar
So the 75/140 is a better choice, right?
Old Dec 13, 2013 | 04:50 PM
ihscouts's Avatar
Too thick for me but a few buds say it quiets their boxes. I don't mind listening to mine whine......
Old Dec 13, 2013 | 05:50 PM
CUpgt's Avatar
I run coastal 85-140 in the TC, diffs, and swivels. I buy it in a 5 gal bucket and change it frequently. Never had any issues.
mx468
Nov 28, 2012 09:00 PM
aarongregor
Oct 1, 2012 02:20 PM
slanginsanjuan
Jun 10, 2012 02:37 AM
greg409
Sep 17, 2010 03:15 PM
malmberg
Nov 3, 2008 06:04 PM
