M/T lubricant??
M/T lubricant??
Noticed a thread on fluids that should be used in an R380. Should I be using ATF or some other fluid?? Already went through two transmissions. The firts was a huge mishap not on my part but a previous owner. The second was incorrect gear oil which resulted in 5th gear failure (Gear exploded and punched a whole in the housing!), again not my fault (Previous owner relied on backyard mechanic who didn't know a Land Rover from Jeep). Looking to prevent another issue. I currently have ATF in it now.
DRAIN THAT ATF NOW!!!
I've only used Redline MTL...here are some references....
Redline MTL - recommended for R380 - Expedition Portal
Gear Oil for Manual Transmission R380
R 380 lubricants
Living in Africa where temperatures seldom drop below 10 deg Celsius but easily get up to 45 C in the shade, I am concerned in using the recommended Dextron II ATF in the manual gearbox (R380)
I have now obtained Castrol Manual VMX W80 GL4.
Is this the correct lub ?
Some Forums recommends SAE 75W80
Disco 1 1997 mod. TDi.
Engin 300i
Manual R380
Transfer T230 T
Engin 300i
Manual R380
Transfer T230 T
