MAF sensor O ring
Old Mar 26, 2012 | 02:34 PM
luckyd77's Avatar
Default MAF sensor O ring
What size O ring goes on the MAF sensor connection to the air filter?
Old Mar 26, 2012 | 02:59 PM
jafir's Avatar
I don't think there is an o-ring on the D1. D2 has one.
Old Mar 26, 2012 | 03:22 PM
ValveCoverGasket's Avatar
i could have sworn there was one on mine also... havent had that apart in a little bit though
Old Mar 26, 2012 | 03:28 PM
Higgs Boson's Avatar
Yes it does take an O ring. No idea what size, take the box and MAF down to NAPA and find one that fits. Rover probably gets $10 for the damn thing.
Old Mar 26, 2012 | 05:16 PM
Chris-bob's Avatar
Yup, as HB said, there is an o-ring. I'll see if I can measure my spare when I get home unless someone beats me to it.
Old Mar 27, 2012 | 12:55 AM
Chris-bob's Avatar
Looks like it is 1/8"thick and 3 3/8" outside diameter(which means the inside diameter is 3 1/8").
Old Jan 10, 2014 | 02:56 PM
rmcshaffry's Avatar
Hello old thread,
I just replaced my MAF on my 04 D2 and there was no o-ring on what I removed (stock original) and no o-ring in the MAF package. Where should I be looking for it - on which end is it fitted (the input or the output)? Both connectors are sleeve-type connectors and fit tightly. The output sleeve is held in place with a squeezing hose connector, and the input sleeve is part of the air cleaner lid and holds the MAF sensor with clips.
Thanks!
Old Jan 10, 2014 | 06:37 PM
TOM R's Avatar
It goes on the MAF input end between sensor and box
Old Jan 10, 2014 | 06:45 PM
wrongway1's Avatar
I just replaced my old MAF with a new-in-the-box MAF. I called & asked the same thing as I didn't have one on the truck & there was no new one in the box. I was told there's not one on the D1.
Old Jan 13, 2014 | 12:21 PM
rmcshaffry's Avatar
Thanks Tom R! An o-ring I purchased at AutoZone fit very nicely in that spot. I took my old MAF in the store and looked for the size in the random-packages-of-o-rings.
Thanks again to everyone on this forum for all your help.
/r
KlamathMatt
Apr 17, 2020 05:27 AM
avking
Jan 15, 2009 12:04 PM
2000 Disco 2 SD7
Jul 18, 2008 03:06 PM
ccvalentino
Jan 22, 2008 06:39 PM
