Massive play in 1997 disco I Steering
Old 11-03-2011, 08:23 AM
Sam95disco's Avatar
Most Rovers are quite capable of becoming a money pit so deep you'll need low range to climb out of it, followed by euphoria, I'll keep it forever, soon followed by the next big money pit in the road. Despair, repair, repay charge card, repeat....
When will it end? I keep seeing LRD 03-04 and I want one, I call them Discos with Range Rover lights.
Old 11-03-2011, 08:47 AM
antichrist's Avatar
No need to replace the drop arm (pitman arm) unless it's damaged, which they usually aren't unless you've been driving a good while with it loose.
Just replace your ball joints, remove the steering damper and do the other checks. Once you correct what you find wrong drive it and if it's ok refit the steering damper, or fit a new one if the old one is worn.
Old 11-03-2011, 09:55 AM
slanginsanjuan's Avatar
whatever you do, do not add up receipts and expenditures. just better not to know some things in life.
Old 11-03-2011, 09:59 AM
...toms list makes a huge difference. i did it all (no shim or bearings) and its better than new. i might even tip her now.
Old 11-03-2011, 11:22 AM
calebbo's Avatar
How many tie rod ends do we need? 4? And how many of the left hand thread and right hand thread?
For the swivels how many upper and lower swivel pins do we need? bearings and shims too?
For the bushings, what is the difference between soft and firm bushings? I am getting the full kit. If I mainly use this as a DD do you guys recommend soft?
Old 11-03-2011, 09:59 PM
ihscouts's Avatar
3 right hand thread, 1 left hand thread.
The swivels don't get replaced unless they are wasted. They can be adjusted. If you really feel the need to spend; RovahFarm for all your new Land Rover Parts and Accessories
I've used rubber bushings, no experience with urethane.
Vinndego
01-06-2014 11:14 AM
xmarksit
11-26-2013 08:37 AM
Cessna310Guy
11-21-2008 10:38 AM
Evian
08-18-2005 11:34 PM
Quick Reply: Massive play in 1997 disco I Steering
