Modify A/C condensor Fan Help
Old Jul 24, 2014 | 03:15 PM
fishEH's Avatar
Originally Posted by MM3846
I figured the switch wouldn't light up, that isn't a big deal. But I don't understand why the wire I'm supposed to ground is hot, and when I ground it sparks out and blows the fuse.
Sounds like you've got the wrong wire, there.
Old Jul 24, 2014 | 03:30 PM
MM3846's Avatar
Nope, RAVE says it's right, 85 off of a relay is ground. It's this weird *** positive grounding thing I don't understand
Old Jul 24, 2014 | 06:02 PM
fishEH's Avatar
Post the RAVE wiring diagram, maybe we can figure it out.
Old Jul 24, 2014 | 06:29 PM
ihscouts's Avatar
Rovers are not positive ground. The switch is supposed to interrupt the ground wire (BN = Black Brown) on 87 of relay K109. So the black/brown wire gets hooked up to the dash switch + and exits on the - switch post. It's same principle as a light switch but your using the relay ground wire. Your interrupting the relay to ground connection, when you do that the positive from the battery is cut off from seeking ground (your dash switch).
Old Jul 24, 2014 | 06:56 PM
MM3846's Avatar
so toss a scotchlock on the BN wire, switching ground?
Old Jul 24, 2014 | 08:09 PM
ihscouts's Avatar
Cut the BN line, use crimp spades (male/female) to run two new wire lengths to the switch. The scotch locks don't break connections they piggy back off them so that's a no go. If you do it right you can remove the switch to return to stock if you go with one male on one cut of the BN and a female on the other cut BN wire.
Old Aug 15, 2014 | 03:21 PM
MM3846's Avatar
anyway, just to update. tossed the ground on 86 of the relay. works mint.
lilherc
Aug 5, 2013 08:37 AM
RegT
Nov 9, 2011 08:41 PM
ssssnake529
Dec 31, 2010 10:44 AM
maddisco
Sep 14, 2009 03:26 PM
Chrisinhouston
Jan 10, 2009 08:58 AM
