My first Disco project
Old Dec 18, 2012 | 03:03 PM
Scope's Avatar
First day off in a while.I changed the plugs and wires today and the engine is purring.I also removed the headliner because of a massive water leak at the rear sunroof.Got that fixed but not sure if I will paint of re cover the liner.Did a fluid change for the transfer case and front diff.Next up is terrafirm shocks and rebuilding rear sway arm.
Old Dec 22, 2012 | 05:59 PM
Scope's Avatar
Today I changed the rear shocks(which wear original) and rebuilt the rear sway bar with all new hardware.The back sits about two inches higher now and handles so much better.Will
try for the front shocks tomorrow.
Old Dec 28, 2012 | 03:14 PM
Scope's Avatar
Today I changed the front shocks,Fuel filter,upper radiator hoses and thermostat.Getting the air out of the system was a pita but it seems to run at about 185.Next on the list is the flex coupling,front stabilizer and shock.
Old Dec 31, 2012 | 09:21 AM
WaltNYC's Avatar
Scope, great work. Textbook Disco rehab. Great to read.
Old Dec 31, 2012 | 10:46 AM
Scope's Avatar
Thanks,I have been wanting a project vehicle for some time and wow did I get the right one!It feels good to save this one from the scrap yard.Perhaps I have been watching too much wheeler dealers.
Old Jan 6, 2013 | 02:59 PM
Scope's Avatar
Today I cleaned the throttle body and discovered a gunked up vacuum line on the right
side of the plenum.I also changed out the original broken radio antenna.There is a great
instructional page on AB for this as it is much harder than I expected.
Old Jan 29, 2013 | 05:57 PM
Scope's Avatar
I will be waiting for tax returns for the next round of parts.While driving home today I heard a loud bang from the drivers side and turned to watch my window slowly drop down. I removed the regulator and found that three spot welds failed. Got the window
taped up before the rain hits and will weld the regulator on my lunch hour tomorrow.You gotta love these disco's.
Old Jan 29, 2013 | 06:44 PM
EricTyrrell's Avatar
Originally Posted by ihscouts
Sounds stupid but it's not like a Toyota where you nudge them and it does a head stand.
I can vouch for this. I drove my old Cressida after a year of driving another car and when I hit the brakes I nearly went through the windshield
Old Feb 8, 2013 | 04:12 PM
Scope's Avatar
Today I put in a new fuel pump.Seems to have a little more pep.I also put in a new regulator.Tomorrow is breaks and rotors all the way around and new o2 sensors and
new shock for steering dampner.If there is time I will install a new driveshaft coupling.
Old Feb 17, 2013 | 12:33 PM
Scope's Avatar
Replaced the flex coupler.THe original had a few cracks.Installed new vinyl on the rear door panel and installed front stabilizer shock. Too cold to anything else.Next is the o2 sensors and brakes,pads,rotors, and bearings all the way around.
