My keyless entry Fob suddenly stopped working=
My Land Rover is a '96 model=
I did change out the battery after the keyless
entry stopped working=
I tried pushing the door locl button 4 times
as discribed in the owner's manual=
didn't work=
light is coming on when buttons are pushed=
I'm a newby LR owner so=????
thanks much
Doc Stone
You've done everything I can think of. Does it not lock or unlock either?
Too bad the 96+ requires a computer to tell the car to learn the remotes.... because the next step might be resync the remote, or replace it and resync it.
start the car? that's not a feature available on a 1996 land rover. It sounds like you have an aftermarket alarm system installed. You might need to check with the manufacturer of the alarm, they may have some steps for pairing the remote with the system.
On a OEM FOB: Pop open the remote. Remove the battery. There are three solder connections on the metal clip that retains the battery. Those connections tend to come loose and need resoldering. It sounds like you might have an aftermarket remote though so IDK. Post a pic of it.
tsuyoi
Sep 22, 2020 10:37 AM
Brad S1
Sep 2, 2008 11:00 PM
