Scary Linkage Problem!
Old Oct 30, 2011 | 06:57 PM
DustyLBottoms's Avatar
Default Scary Linkage Problem!
So today I decided to finally lube my transfer case linkage, it's been a bear to get into gear.
After drilling out the rivets, and removing the cover plate I find this:
http://www.flickr.com/photos/37974521@N03/6296326375/http://www.flickr.com/photos/37974521@N03/6296326375/ by http://www.flickr.com/people/37974521@N03/, on Flickr
The 13mm bolts that hold down the upper housing were LOSE and allowing the housing to move with the shifter.
Even WORSE....look closely. The screw acting as a dowel pin HAS NO RETAINING NUT. I was able to reach down and pop it right out.
So, I packed the housing full of synthetic grease, applied lock-tite to the 13mm bolts, and then added a nut, washer and lock-tite to the linkage screw.
All in all, I was very thankful to have caught this before it left me in perma-neutral somewhere dangerous.
Old Oct 30, 2011 | 07:16 PM
Dodged a bullet, buy a lottery ticket. Good catch. Bask in the glory. Meanwhile, Murphy's Law has re-grouped and is hard at work on the next issue....
Old Oct 30, 2011 | 07:40 PM
Tell me about it, my volvo is starting to feel neglected. Since I got the rover, I've spent every weekend working on it.
Old Oct 30, 2011 | 07:51 PM
EricTyrrell's Avatar
Good catch. You wouldn't believe how many loose bolts I found holding my ENGINE together...
Old Oct 30, 2011 | 08:04 PM
The real test of a young Jedi is how many bolts are left when the engine is back together.....
Old Oct 30, 2011 | 11:37 PM
Danny Lee 97 Disco's Avatar
All the loose bolts could have been the major cause of the problems as well.
I just replaced a front load washer because of problems and decided to scrap out the old one. When I disassembled it, the problems were initiated by loose bolts!
Good catch on that linkage problem.
Old Oct 30, 2011 | 11:51 PM
calebbo's Avatar
anyway to find the sizes of those bolts? I need a few
Old Oct 31, 2011 | 12:23 PM
Rovers North should have all of that in stock. Give them a call. I bought a lot of new hardware from them when I redid my linkage.
bangkuaidiscovery04
May 11, 2009 10:00 PM
Spike555
Nov 14, 2008 09:07 PM
Bob2003Discovery
Jan 17, 2008 12:12 PM
alanroberts50
Dec 12, 2007 12:30 PM
ferrelltodd
Jan 26, 2006 01:23 PM
