My keyless entry Fob suddenly stopped working=
Old Oct 30, 2011 | 04:51 PM
Doc Stone's Avatar
4wd High
Default My keyless entry Fob suddenly stopped working=
any help would be appreciated
thanks
Doc Stone
Old Oct 30, 2011 | 05:02 PM
adigerol77's Avatar
Doc, possibly the batt in the fob? Did you change anything lately that would cause a reset?
Old Oct 30, 2011 | 06:29 PM
jafir's Avatar
also, what year is your disco? You might want to make it part of your signature, as it will help the community help you.
Old Oct 30, 2011 | 11:57 PM
Doc Stone's Avatar
4wd High
My Land Rover is a '96 model=
I did change out the battery after the keyless
entry stopped working=
I tried pushing the door locl button 4 times
as discribed in the owner's manual=
didn't work=
light is coming on when buttons are pushed=
I'm a newby LR owner so=????
thanks much
Doc Stone
Old Oct 31, 2011 | 12:22 AM
jafir's Avatar
You've done everything I can think of. Does it not lock or unlock either?
Too bad the 96+ requires a computer to tell the car to learn the remotes.... because the next step might be resync the remote, or replace it and resync it.
Old Oct 31, 2011 | 06:07 AM
Doc Stone's Avatar
4wd High
No,
it will not open, lock or
start the car=
guess I'll just have to use the keys=
thanks for the interest=
Doc Stone
Old Oct 31, 2011 | 07:37 AM
jafir's Avatar
start the car? that's not a feature available on a 1996 land rover. It sounds like you have an aftermarket alarm system installed. You might need to check with the manufacturer of the alarm, they may have some steps for pairing the remote with the system.
Old Oct 31, 2011 | 08:42 AM
fishEH's Avatar
On a OEM FOB: Pop open the remote. Remove the battery. There are three solder connections on the metal clip that retains the battery. Those connections tend to come loose and need resoldering. It sounds like you might have an aftermarket remote though so IDK. Post a pic of it.
Old Oct 31, 2011 | 08:49 AM
Doc Stone's Avatar
4wd High
I will post a pic when I get home tonite=
yes, it would remotely start the car, when
working=
thanks=
Doc
Old Oct 31, 2011 | 09:01 AM
There is the problem, it is an aftermarket remote which usually cause problems at some point.
tsuyoi
Sep 22, 2020 10:37 AM
Frank4
Mar 21, 2014 05:21 AM
Mark G
Sep 17, 2008 07:23 AM
Brad S1
Sep 2, 2008 11:00 PM
faith2
Sep 14, 2005 03:04 PM
