My Winch Bumper Project
Old Feb 7, 2012 | 04:42 PM
  #21
Mountain Goat's Avatar
Originally Posted by hilltoppersx
now you're talking with that second pic! that little metal thing your insurance wants you to put on is useless. i wouldnt even bother. but then again im ruthless. i just re-read my earlier post. i must have been drunk. every time i said vertical i meant horizontal and every time i said horizontal i meant vertical. haha....
Yeah once I figured out you were confused I knew what you meant.
I may or may not get around to adding the skirts, it really depends how well the project is going and how much time I have. Looks better without it IMO.
Like I said, the skirts really won't affect approach angle in any significant way, I may at least do a mock-up to see how it looks.
Old Feb 7, 2012 | 07:30 PM
  #22
jafir's Avatar
It says you are allowed 30"
You are four wheel drive, with less than 10,000 lbs.
EDIT: Actually I read it again. There is no height measurement needed if you have a bumper installed in the stock location. I just has to be in the same place as the original, and at least 4.5 inches tall. The 30" is for trucks that are exempted.
Old Feb 7, 2012 | 08:57 PM
  #23
K I reread it and exempted trucks measure to the frame rail. 4x4s under 10,000 lbs get up to 30 inches under the bumper. That I can live with, so I'll keep my original design and slice a Honda CRV in half if we ever have a wreck!
Old Feb 7, 2012 | 11:21 PM
  #24
Danny Lee 97 Disco's Avatar
Can you post the overall dimensions. I was just given some really heavy steel frames that came off PLC racks from a US Steel Training center. These are 6 feet tall rectangular cabinet frames made from some awesome steel plate that is 8 inches wide with a formed lip on both sides. I keep looking at possibly cutting one into two pieces to make both a front and rear bumper.
I'll have to take some pics soon.
Old Feb 7, 2012 | 11:38 PM
  #25
I will post some dimensions when they are definite. Won't know precisely what it needs to be until I take the bumper off and do a bit of a mock-up.
Old Mar 4, 2012 | 03:48 PM
  #26
I have some updates from the last two weeks.
Removed the old bumper:
Used a CNC plasma cutter to cut out the fairlead opening:
Do not attempt to bend a winch tray like this unless you have a huge brake press. Even the giant Piranha press in the background took several tries to bend this completely:
Cut out the mounting plates with a hand-held plasma cutter:
Old Mar 4, 2012 | 03:53 PM
  #27
Test-fitting the mounting plates:
Tack-welded two mounting plates together for each side, then marked and drilled holes:
Used the winch tray to even out the mounting plates:
Tack welded tray to mounting points:
Old Mar 4, 2012 | 03:54 PM
  #28
Lots of welding:
That's all for now. More to come over the next few weeks.
Old Mar 4, 2012 | 04:39 PM
  #29
vandev's Avatar
Default looks great..
Looks great....We all talk about making one but we never do...You did...awesome job....Will be following your post....
Chris
Old Mar 4, 2012 | 04:43 PM
  #30
turf63's Avatar
welds look like they're def getting better. You're not recessing the winch into the grill at all? looks like it'll stick out a bit, but on the whole very exciting project. Keep it up. Gonna powder coat it or rattle can it?
