Need Advice regarding '96 Discovery I
Old May 12, 2018 | 04:54 PM
Discoveryfan's Avatar
Default Need Advice regarding '96 Discovery I
Hello all. I am new to this forum to please have patience. I bought a 1996 Discovery I for my daughter to drive while in college. I did a good bit of work, new injectors, brakes, hoses, fuel pump, etc. It ran fantastic and I drove it to my daughter in Texas to use while she was at he University. I like the LR so much that I told her I would buy it from her, which I did last month, sight unseen. I went to pick it up and found that it had been run hot and was steaming from the exhaust. I live 750 miles away and need some advice on repairing it there in San Marcos, Tx or attempting to haul it back to Georgia. I may just cut my losses and sell it, but I really want to fix it and drive it daily. Any advice will be most appreciated!
Old May 14, 2018 | 10:31 AM
WaltNYC's Avatar
Worst case scenario you are looking at a head gasket. $2000-3500 job depending on the shop you use and how many other "while you're in there" items you want to replace/renew.
Are you losing coolant and need to refill the reservoir frequently? Are there exhaust gasses in the coolant (can purchase a test from auto parts store).
It is difficult to say much more without any info
Old May 14, 2018 | 11:25 AM
robertf's Avatar
That is not the worst case scenario. Cracked cylinder wall/liner would be the winner.
You should have it towed here and see what they say
https://www.hillcountrybritish.com/
Old May 14, 2018 | 11:46 AM
fishEH's Avatar
You can do it yourself for FAR less, even with having the heads skimmed.
Old May 14, 2018 | 09:15 PM
Thank you! I think I will contact hill country british. I'll keep y'all posted
Old May 17, 2018 | 11:58 AM
Gimebakmybulits's Avatar
KSeal has kept my 98 on the road for over a year after finding that it has a cracked block. Just trying to decide if I want to drop a long block in it. A leak down test should pin point the issue for you.
Old May 19, 2018 | 09:58 PM
Johnny K's Avatar
Go Bobcats!!!
DiscoShelt
Dec 17, 2014 01:11 PM
jck09
Jan 13, 2011 08:57 AM
NWDiscoRover2004
May 1, 2010 12:00 AM
KBW
Sep 1, 2009 08:09 PM
LRDiscGirl
Feb 15, 2009 09:53 AM
