Need assistance removing D1 tranny pan and filler tube
I am going to a boneyard tomorrow and I really need a primer on every thing that i will need to remove a D1 tranny pan and filler tube. Specifically:
1. What tools will I need or would be nice to have around
2. Pit falls on pulling these parts out, firstly the filler tube mounting bracket which appears to be in a tight space behind the engine and also removing the huge subframe brace to get the tranny pan out
Any help is greatly appreciated. Thanks.
The frame stiffener is a beeotch to get out even with a large rubber coated fine adjustment tool. A bottle jack with a short block of wood in between the frame rails can give you that little bit of yaw to drop it without much beating. How you hold it all in place while using the jack handle is up to you......
Also, what tools do I need what size is the nut for the filler tube?
