Need help with RAVE instruction, Re:Transmission swap
Old Jul 27, 2010 | 12:19 AM
Disco Den's Avatar
Default Need help with RAVE instruction, Re:Transmission swap
Hello again! So I'm getting close to the actual removal & replacement of my transmission/t-case. I'm reviewing the instructions in the RAVE & there is one thing I am not clear about, & I'm hoping someone can clarify for me.
On page 440, step 48 says: "Position hoist jack channel under engine and
support using a wooden block." This is after the transmission/t-case is secured to the transmission hoist, & after step 35, which is "Lower hoist until rear brake drum clears passenger footwell. Check engine does not crush any components while lowering."
So I'm wondering What exactly is a hoist jack channel, & what hoist is this particular one on? Is it a second jack used solely to hold up the rear of the engine in the absence of the t-case mounting brackets? That's all that makes sense to me, but if someone knows for certain I'd like the clarification before I kill myself doing something stupid!
Thanks!
Old Jul 27, 2010 | 05:20 PM
http://www.harborfreight.com/800-lb-...jack-3185.html
That is a trans jack, notice the "channel" that the trans sits in so it wont roll onto your skull or the ground?
Yes you need a jack to keep the engine from falling onto the ground, you could use a jack stand, or a bottle jack (like the trucks jack), just use a block of wood just like they say.
To much force on the aluminum you could break it.
Old Jul 28, 2010 | 07:12 AM
antichrist's Avatar
You're better off making the support cradle that is in the RAVE and fitting it to the jack Spike linked to, or something similar.
I adapted mine to fit my floor jack since my jack has a removable saddle.
Old Jul 28, 2010 | 09:20 AM
Disco Den's Avatar
I made the cradle. Which is why I'm still unsure of what the channel under the engine is. This step is after the Trans/T-case assembly is attached to the cradle & is being supported by the trans jack. The cradle attaches at the rear of the t-case & goes to the ATF oil pan... nowhere near the engine.
I'm sure that the instruction is saying support the rear of the engine, but I wanted to make sure I'm reading it correctly. I guess I'll know for sure sometime today!
Old Jul 28, 2010 | 09:13 PM
Disco Den's Avatar
Alright, I won't find out tonight. I made the cradle bracket exactly as designed in the RAVE, but the front 90* angle bracket should be set 6-7mm farther forward (more distance between the front mount & the rear mount plate.
I'll give it another go tomorrow.
OffroadFrance
Feb 23, 2015 05:32 PM
wynhd
Feb 8, 2014 07:20 PM
Discolife
Jun 7, 2012 01:21 PM
salve7
May 18, 2010 03:49 PM
hotelmez
Jul 21, 2008 02:14 PM
