Need Shop in Portland Maine
Well well - really interesting what Overland Engineering found that left me stranded in Maine after a cross country trip - my Transfer Case was empty ! no obvious leaks - the transfer case oil was changed about 10k miles ago by well known LR independent shop in Santa Fe and I watched them do it - now looking at a swap out or rebuild - no obvious spots on my drive to tip me off - where did the oil go ? this is a 30K mile change item - I made 4 previous cross-country trips with no problem - strange
it appears that the breather hose on top of the transfer case slipped out of the holding bracket - it ended up being on the exhaust and melted shut - forcing the gear oil to spray out thru a gasket and coat the bottom of my Disco - thus no drips or leaks on the drive - and running it dry and causing it to break the bearing and finally seize the gears up - what a mess that was - I was saved by Matt Browne at Overland Engineering in the Portland ME area
